Beomaster 1900-1 stand-by fault [solved]
Hi, I have this curious fault. The Beomaster 1900 switches on as it should, with any source button, , everything works just fine. FM works too. Trouble is, when I want to switch it off, the lights come out, except that the 31 V never switches off, and obviously the volume lights, the tone control and balance lights don’t go out. The amp never really switches off. Shorting TR25 activates standby as expected. How can I test IC6?   Cheers, Jacques
Jacques
I cracked it – TR25 was bad after all, but is still fine on the bench, statically. I had it in the drawer, a BC172B. Good on the tester then but bad under pressure. I just shorted EC and found out the Beomaster switched off doing that. I hate that kind of fault! A transistor is dead but it wants to live when tested with low voltage… The BM1900 now switches off normally, and as suspected IC6 is good (it measured so). Thanks for looking. Jacques
Jacques
Good find Jacques
Retired Printing machine technician Restored various 1960-70 items Rock and Roll music Collecting Vinyl Restored Jukebox Wurlitzer 1050
Yes, nice work Jacques.
Thanks ?
Jacques
Remember guys when we posted all those repair threads back in the day? Have people just lost interest?
Jacques
Hi Jacques, Yes, I learned a ton from you and the other Workbench regulars.  I owe you guys a big thanks.  With Martin guiding us when necessary we accomplished and learned a lot. I still do a lot of restorations but on a blog now.  For me it allows for a better structuring of the restoration story and the presentation has better media (photo) options. I think that restorations have increased now.  Martin's Beoparts store has some really great parts a DIY restorer can find and use so I think there is a lot going on. John
I'm still here, but far from as active as previously. Others have left altogether and found other places. This thread is perhaps not the best place to discuss it, but I have my reasons for now visiting merely a couple of times weekly rather than a couple of times hourly. I can only imagine, that other members, be that  "surviving" or previous, have their reasons as well. Perhaps some or all of the reasons are the same. And I don't think it has anything to do with the "misunderstandings" mentioned above, really. They merely stirred things up a bit and added energy to the forum life. But I agree, they seem to have gone as well. Martin
Hi, Usual stuff… done ? This 1900 type 2903 is not the most cleanly executed, as regards PCB. Lots of solders still had a lot of flux around. The later 1900-2 was much cleaner. Looks original too. Someone had indeed been there before but wasn’t up to fixing it (as usual, touch panel not correctly mounted, etc).   Now looking for someone to veneer the trims. The previous owner just removed it from the front, advertising it as mint ? Unless someone here has new or mint ones, that is! Martin, how come you haven’t come up with a re-veneering service yet? ? Edit: is that why there are so many white ones? ? Jacques
Jacques
